Maruti Suzuki Baleno 2015 Zeta (Petrol): Ownership Review. This is a discussion on Maruti Suzuki Baleno 2015 Zeta (Petrol): Ownership Review within Ownership Reviews. Part of The Automotive Reviews category; Quote:
Originally Posted by shalabh
Mine is petrol. Don't know if petrol has the same issue. I feel there is ... |
18th December 2015, 01:57 PM
#316 | V10
Award Points: 10
| Re: Maruti Suzuki Baleno 2015 Zeta (Petrol): Ownership Review Quote:
Originally Posted by shalabh Mine is petrol. Don't know if petrol has the same issue. I feel there is some sort of an offset in the clutch. | Get it corrected at Maruti ASS. ameyam also had a similar issue in his Baleno Petrol. The clutch pedal wasn't well modulated, the biting point was too early, and this didn't allow him to start the car sometimes (as clutch wasn't fully depressed). Notchiness in the gears points to this issue IMO. |
18th December 2015, 04:31 PM
#317 | V4
Originally Posted by amitvj24 atlex123-
Thanks. I wont be going for bank loan.
harrajbal-
Good to hear 100% refund. How much time he will take to give it back? I heard they might take months to give back the refund amount.
I had called toll free number for NEXA too.
They mentioned that for Delta Petrol, waiting period is indeed 16-18 weeks. | no refund should not take months.. you should get refund within 8-10 working days.I got mine (accessories refund cheque) in 4-5 days, but you need to push them for couple of times though. |
18th December 2015, 04:48 PM
#318 | V6
| Quote:
Originally Posted by samirpatry @Shir
No not yet from RM.But from my company colleague who booked on 20th Nov is going to get it next week same zeta petrol ray bule. Do not understand the formula for this.i will visit 2moro to get it clear. | Ok that is strange. Did he booked from the same showroom near sadashivnagar mandovi ? Which varient for him ? I booked zeta petrol.
keep me posted please, i will check with RM then and get it clarified. THANKS. Quote:
Originally Posted by atlex123 no refund should not take months.. you should get refund within 8-10 working days.I got mine (accessories refund cheque) in 4-5 days, but you need to push them for couple of times though. | correct Refund should not take more then 7 working days. However the dealer need to initiate it from his end on time.
Reason: Back to back post, use multiquote function.
18th December 2015, 04:55 PM
#319 | V4
Originally Posted by @shri Ok that is strange. Did he booked from the same showroom near sadashivnagar mandovi ? Which varient for him ? I booked zeta petrol.
keep me posted please, i will check with RM then and get it clarified. THANKS. | @Shri
Yes same sadashivnagar mandovi . Zeta petrol ray blue. he was on leave today but i heard from another friend that he got login for Nexa. i am planning to go there 2moro to check with my RM. |
18th December 2015, 05:01 PM
#320 | V6
Originally Posted by ice_wise Get it corrected at Maruti ASS. ameyam also had a similar issue in his Baleno Petrol. The clutch pedal wasn't well modulated, the biting point was too early, and this didn't allow him to start the car sometimes (as clutch wasn't fully depressed). Notchiness in the gears points to this issue IMO. | Thanks Ice wise. We can check this before taking the delivery i guess. Is this a fault with all the petrol versions or just one of the case ? Also as you mentioned in you post earlier the door panels are bending easily ? So which means if small brush from any side will give it a dent ? In Bangalore its hard to drive between lanes so m worried ? Folks in Bangalore can understand where am coming from. |
18th December 2015, 07:21 PM
#321 | V10
Award Points: 10
Originally Posted by @shri Thanks Ice wise. We can check this before taking the delivery i guess. Is this a fault with all the petrol versions or just one of the case ? Also as you mentioned in you post earlier the door panels are bending easily ? So which means if small brush from any side will give it a dent ? In Bangalore its hard to drive between lanes so m worried ? Folks in Bangalore can understand where am coming from. | Even Delhi has similar traffic conditions @shri. I had said that suppose you lean on any door, it will slightly bend inside, but will come out to original position as and when you get away from the door. It does not form any dent. It is the same with my Swift too, where the roof bends (but comes back), doors bend and bonnet does bend sometimes. But bending is temporary and as soon as you release pressure, it will come back to original position. So don't worry.
And yes you can check it during delivery. Since yours is a Zeta, you can depress the clutch normally and see if the start stop button works perfectly or not. I found this issue in the Petrol TD car (drove only Petrol) and ameyam also mentioned about it. |
18th December 2015, 07:37 PM
#322 | V6
Originally Posted by ice_wise Even Delhi has similar traffic conditions @shri. I had said that suppose you lean on any door, it will slightly bend inside, but will come out to original position as and when you get away from the door. It does not form any dent. It is the same with my Swift too, where the roof bends (but comes back), doors bend and bonnet does bend sometimes. But bending is temporary and as soon as you release pressure, it will come back to original position. So don't worry.
And yes you can check it during delivery. Since yours is a Zeta, you can depress the clutch normally and see if the start stop button works perfectly or not. I found this issue in the Petrol TD car (drove only Petrol) and ameyam also mentioned about it. | certainly i will check. Your posts are always informative i must say @ Ice Wise |
18th December 2015, 08:03 PM
#323 | V4
And yes you can check it during delivery. Since yours is a Zeta, you can depress the clutch normally and see if the start stop button works perfectly or not. I found this issue in the Petrol TD car (drove only Petrol) and ameyam also mentioned about it. | thanks
although its not happening in my ikon, but i guess this is the problem with all new sheet metal car i checked wagonr also have that effect. |
18th December 2015, 09:38 PM
#324 | V4
Originally Posted by ice_wise Get it corrected at Maruti ASS. ameyam also had a similar issue in his Baleno Petrol. The clutch pedal wasn't well modulated, the biting point was too early, and this didn't allow him to start the car sometimes (as clutch wasn't fully depressed). Notchiness in the gears points to this issue IMO. | I'm thinking about getting it done during first service. I hope driving it like it is for a month won't harm the car in any manner. Please advise. |
18th December 2015, 10:17 PM
#325 | V10
Award Points: 10
Originally Posted by shalabh I'm thinking about getting it done during first service. I hope driving it like it is for a month won't harm the car in any manner. Please advise. | Yes, I talked to TSIVipul and he says that it is best to change it after covering at least 500 km. So first service would be absolutely fine. |
19th December 2015, 10:04 AM
#326 | V4
| Re: Maruti Suzuki Baleno 2015 Zeta (Petrol): Ownership Review Anyone has experience buying car in Navi Mumbai/Mumbai? I will be mostly booking the car next weekend. So wanted to know which NEXA dealer to go for booking?
Till now, I have taken 2 TDs at S K Wheels, Turbhe as I stay in Navi Mumbai and have interacted with them only. There is always too much rush there and not sure how would be the experience later as till now NEXA experience has been worst than Mumbai local experience.
But, I think I can also go with other NEXA dealers in Mumbai as well. So, wanted to know if I can go to some good dealer and mainly if anyone has good relations with any one dealer? |
19th December 2015, 12:49 PM
#327 | V6
Originally Posted by samirpatry @Shri
Yes same sadashivnagar mandovi . Zeta petrol ray blue. he was on leave today but i heard from another friend that he got login for Nexa. i am planning to go there 2moro to check with my RM. | any update you got samir ? Let me know pls if needed i will visit there tomorrow or Monday..
19th December 2015, 04:02 PM
#328 | V2
Originally Posted by amitvj24 Anyone has experience buying car in Navi Mumbai/Mumbai? I will be mostly booking the car next weekend. So wanted to know which NEXA dealer to go for booking?
But, I think I can also go with other NEXA dealers in Mumbai as well. So, wanted to know if I can go to some good dealer and mainly if anyone has good relations with any one dealer? | Hi Amit,
We got our Baleno from SK Wheels Navi Mumbai. The dealer experience was not at all great as the RM assigned to us was always giving false info on delivery, allotment, etc. We always had to bypass him and speak to the showroom manager or CRM for right info. I had also got in touch with Maruti Suzuki Regional Manager for processing the allotment of our car.
We went to Navi Mumbai from Mumbai, as the RM told us he can deliver the vehicle in time, but I guess we all know that is not happening at any NEXA. I had been to most NEXA showrooms in Mumbai. I found one at Andheri East (Shivam Autozone) the best, Sai Service at Parel is also good. You can try these. At Shivam speak with Darshan is a good chap
Also one advice would be, if you can manage reach any NEXA showroom early in the morning by 9.30 - 10.00 AM for good quality service and TD.
Hope this helps! |
19th December 2015, 06:52 PM
#329 | V2
| Re: Maruti Suzuki Baleno 2015 Zeta (Petrol): Ownership Review Hi all,
Thanks for making me a member.
Though i am a new member hre i know all you guys becaz i ve been reading each and every coment you all mark about baleno.
I wud like to know the modifications which could be done on baleno headlight so tat it looks better.
i really like the alpha head lights. but Upgrading to alpha from delta needs another 1.5 L to be invested.
wud like to kow your valuable inputs on this. |
19th December 2015, 07:30 PM
#330 | V6
Originally Posted by @shri any update you got samir ? Let me know pls if needed i will visit there tomorrow or Monday.. | @samir, i visited Nexa today and spoke to my RM, still he says the allocation is due. He said before Jan end he will give the delivery.
let me know if your friend got the delivery, i will take it further from there then. Thanks |
| | Thread Tools | Search Thread | | | All times are GMT +5.5. The time now is 12:24 PM. |
