DIY Dent Removal and Painting
pathankot
Dear all
i use esteem vx which was scrached and dented while reversing it now i am removing dent my self and do paint on it my self see pics for update of the process
dent removal done
putty work done
sanding also done
please guide experts[frustration]
Well, with all due respect, raman, if you are not using a pulling bridge to pull out most of the dents before going to work with the filler, you are not doing the right thing. Filler is great in overseas cars where the metal gauge is thick and doesnt flex. If you do it on the thinner local gauge metal, the filler will crack when the panel flexes such as when someone leans against it and will showup in the paint work as a crease or crack. So, just a suggestion, have a good painting shop do it for you
Ameyam
+1 to Ameyam.
It is always good to go with the professionals.Do you have all the machines required for filling and polishing? There is also a need for eye for the colour,else that creates a big difference in the outcome.
Kuwait City
Hi Raman, along with the pics can you please post some detailed information like how you did it, what all are the tools and other equipments you used?. Then only your DIY can be useful for the fellow members if at all anyone is interested to pull off this complex DIY.
pathankot
Dear members
thanks for suggestions but i have started work an also purchased some of the main machines required.
i have firstly pulled dents then applied filler
now surface being made ready for surfacer(primer)
i will buy paint from professionals (may be computer controlled machine)
keep watching
mayankdixit
kanpur
My God,You are way ahead all of us, venturing into even denting and painting.!!!.Bravo. By the way what the hell is that machine. Looks like a mini compressor of sorts.
pathankot
eid mubarak to all
i celebrated this way
front side bumper and fender complete done
bonet clear coat left
i got 500ml 0f paint+600ml of thinner
500ml of clear+activator total cost 1550/-
pathankot
see pics
your reviews
pathankot
more are coming for pending work on sunday
sanding 1000g paper to be done on bonet
