Re: Need help on rested Chromes You can use aluminium foil for this purpose. Take the foil (the one used for packing food items) and cut a section of about 4x4 cms dip this in water and rub lightly over chrome surface. Once the foil changes its colour cut another section from the foil roll and then continue the same process to get rid of the rust.
How this works hardness of foil is less than that of chrome so it will not scratch it and it will remove the rust. You can also use "Brasso" to do this as well, Brasso is available at general stores. |
