Glue Stain Remover
Thane
Hello Friends !
My car's windows sticker removal have developed glue stain giving a bad mark on the glass . Please advice a solution for removing these stains [confused].
Thanks !
Try removing the adhesive with an old plastic card and then clean the window with some glass cleaner like Colin.
Let me give u the best, easiest and almost magical method of removing this.
First try to just take brown sticky tape. The big wide 2" wide ones ? And stick it on the glue are and pull. Sometimes you can completely remove any glue residue very easily with this method.
Second and sure fire method which ive used, and regularly use at home is WD40. It works like magic. Basically it disolves any adhesive materials instantly, lubricates and cleans rust of any surface. You get WD40 spray cans in automotive dealer shops.
Spray a little to the sticker or the adhesive gets soaked. Wait for 2 mins and just wipe with a cotton cloth that has a slight texture (if not even normal cloth will do), it will come off as if you just wiped some fingerprint off your glass, very easy and effortless method. :)
