As
@bhvm has pointed out, it is due to centripetal force on the valve.
Let's do the calculation. The Bugatti Chiron has a Michelin Pilot Sport Cup Tires size of 285/30R20 front tyres so inner diameter is 20 inch (0.508 metes) and outer diameter is about 26.8 Inch (0.68072 meters).
Distance traveled by this tire in
1 rev = 2 x pi x r = 2 x pi x (0.68072/2) = 2.13854 meters.
The speed of Bugatti Chiron is
261 mph which in meters per minute = 261x26.822
= 7000.65 meters per Minute.
At that speed, the tire
revolution per minute = 7000.65 / 2.13854 = 3273.57 rpm.
We need to convert this to radians per second. As you all know, there are 2 Pi radians per revolution and 60 seconds per minute so
3273.57 rpm = (3273.57 x 2 pi ) / 60 = 342.80 radians per sec.
The valve is located on the rim, so we will take the inside radius of the tyre , which is 0.508 / 2 = 0.254 meters. Thus the Centripetal Acceleration on the valve = (radians per sec)^2 x radius = (342.807)^2 x 0.254 =
29849.2 m/sec^2
We all know that the a
cceleration due to gravity is 9.8 m/sec so, the
valve will experience 29849.2 / 9.8 =
3045.84 Gs hence the 2.5 gm valve will weigh (apparent weight due to G force)
2.5 x 3045.84 = 7614.6 gms = 7.61 kg =
16.78 pounds !
HTH
