My assumption of what could have gone wrong, seeing the failed parts (Toe control Rod & one of the link rod)
- Vehicle losing control or spinning needs one (or both) of the wheel(s) to deviate from the geometry. In simple words, go far out of alignment under dynamic condition.
- This can happen when one of the connecting link fails (may be due to the excess load put on them as result of flat tire)
- In specific to the subject vehicle, weakest link on the rear suspension is Toe Control Rod or the rear Tie-Rod
- Failure sequence : Flat Tire (may or may not be) --> Toe Control Rod --> Upper Link Rod bush --> Vehicle Goes out of control / spinning
When can Toe-Control Rod fail?
- Manufacturing Defect
- Accident / Physical damage or Hit (on the part itself)
- When the
adjustment nut is not tightened or loosening as a effect of so many reasons
Last option is more likely to happen
IF the statement of both M&M and Customer is true.
when was the vehicle last serviced or wheel alignment done?
1. Toe-Control Rod
2. Upper Link Rod (This bush is designed to take articulation only to the level of suspension link geometry change (suspension / wheel travel) and adjustment range of Toe control rod. Anything beyond that will make the bush to dislocate)
Reference image of 2WD XUV rear suspension link. Toe control rod marked in Red (both ends are Aluminium, and they are the weakest structure in entire rear suspension)
