Steps.....
1). pull and remove the horn cover.
2). remove the supply to horn switch.
3). remove the metal connector parts of horn from steering
4). un-tight the center mail bolt of steering wheel and pull it up.
5). remove the lover side plastic cover.
6). cover the metallic parts with any suitable fabric. I use same fabric use for seat covers.
Thanks
oh..... i transfer place of horn switch to just under the lower side of steering column cover (use new press switch)
Also i covered the center bolt with black rubber knob, it gives nice look. (NOT IN THE PICTURES)
Thanks
