> Your Car: I want to upgrade the ice of my polo comfortline
> Budget Range: have a tight budget of inr 15k
> Existing Audio Setup: It has stock hu rcd 220 and stock speakers with a v12 4 channel amp, convex company sub woofer and Some wiring that is 8ga powered directly from battery, don't know what brand.
> Looking For (Full Setup, Head Unit etc.) I am hoping to achieve the following in this budget :
1. Get a new amp
2. Upgrade front components
3. Sound proofing.
Amp upgrade being the priority as its giving problems. Sound proofing could be moved to stage two if the budget doesn't allow to get all three done.
I am thinking that I could power the rear speakers from the hu and the front speakers and the sub with a 4 channel amp.
> Preferred Brands (If any): no preference as such. Just should be a reliable brand.
> Preferred Music Genre: I listen to edm songs and occasionally bollywood. Would like a balanced SQ and SPL setup which fits in my budget. Though I do like bass.
> Misc. Details / Specific Questions: I am a complete noob and have no knowledge about Ice so please help accordingly with complete details.
The amp I guess isn't good. it's about 6 years old from my old car santro and so is the sub woofer. I had to get the amp repaired once and still if I use it in bridged mode it heats a lot and the sound dips low. Will upload snaps of the sub and amp if required.
> help required - Please give me recommendations for the components , amp and sound proofing which would fit in my budget. Looking for VFM options. Won't mind using 2nd hand products if in good condition.
Also I am open to any other advice you gurus might give except that I wouldn't change the hu probably.
Also do recommend any tried and tested shop I can go to for my ice setup preferably in Ghaziabad if you know any or else Delhi. But it should not be expensive options as I have a tight budget.
1. Get a new amp
3. Sound proofing.
