Hi all,
Its a long time, I have been without car, finally I have worked hard and finalized Baleno.
I will be booking it on this Shivratri(24 Feb)
I am very tight on budget and still deciding between Nexa Baleno Delta/Zeta.
Need your advice on the same.
Music is indeed very important for me and I have thought of upgrading it as the stock speakers aren't at par.
I would be using default HU, however would like to modify the speakers and add a good amp with a sub woofer.
Nexa has its own accessories and installing it from dealer won't affect the warranty.
Nexa has Component Speaker**with Spacer (Hertz) Front for rs 6500, would like to know if its worth.
Also they have 2 amps available to choose.
Amplifier Channel 1500W 26590 and Amplifier 2 Channel 400 W costing 26000 and 11000 respectively.
I would be adding a after market sub woofer later.
Requesting you to please suggest.
