My car :Skoda Rapid
Requirements :
Double din screen (DVD player +reverse cam view , +Maps /satnav,), not necessarily touchscreen,. It should be compatible with the present steering mounted audio controls & Bluetooth steering mounted telephone control.
Desirable but not compulsory features :
If it includes TPMS, it would be desirable but not compulsory
I have read about Blaupunkt android Cape Town 940 HU & Blaupunkt philadephia HU. But they are out of budget as of now.
Budget : Rs 40 k
Present ICE set up :
HU - OE double din
Speakers : OE,
I am planning to replace front component speakers in future, if the SQ is found to be unsatisfactory.
Subwoofer -
I have already installed a subwoofer with following specifications
Closed subwoofer enclosure with integrated Class-D amplifier;
Amplifier-
Type: Class-D (Digital)
RMS power: 500 watts
Max.Power: 1.000 watts
Frequency range: 25 – 200 Hz
Signal-/Noise ratio: >91 dB
Adjustable gain: 0.2 – 5V
Variable lowpass filter: 50–200 Hz
BassBoost: 0 – 12 dB
Phase: 0 - 180°
Inputs: 2x Cinch/RCA, 2x Highlevel
Automatic power On/Off function
Special connector for 12V/Ground/ Remote signal (6-Head screws)
Power-on indicator: 2-color LED (blue / red)
Subwoofer-
Diameter: 300 mm
Membrane material/color: SPC (Spune Paper Cone) / black
Rated power handling: 500 watts
Peak power handling: 1.000 watts
Impedance: 0.2 ohms
Frequency response: 25 – 200Hz
Sound pressure level 2.0 V/m: >91 dB
Material/Color speaker cover: ABS / silver
Material/Color grille: Metall / black
Enclosure
System: closed housing
Housing volume: 32 Liter
Material: MDF
Coating/Color Front/Back/Base: special foil with ribbed surface / antrazith
Coating/Color side panels: foil / silver
Dimensions W x H x D: 397 x 480 x 250 mm
Dimensions W x H x D: 15.6" x 18.9" x 9.84"
Delivery contents
Subwoofer enclosure
Special connector for 12V/Ground/Remote signal (6-head screws)
Cable remote control (GAIN adjust)
Adapter for High-Level input
Fuse 20A
So the HU must be be compatible with this subwoofer.
preffered brands : reputed brands.
Requirements :
Budget : Rs 40 k
HU - OE double din
Speakers : OE,
Subwoofer -
Amplifier-
Phase: 0 - 180°
Subwoofer-
Diameter: 300 mm
Impedance: 0.2 ohms
Enclosure
Material: MDF
Delivery contents
Subwoofer enclosure
Fuse 20A
