Hello,
I purchased a Pioneer F60BT today and got it installed through local accessory store, The installation was smooth and they used a harness and no cables were cut, but the behaviour of the head unit is strange for power.
It turns off as soon as i switch off my ignition. It also restarts when I turn on the engine. (being on on ACC on position)
It should turn off when I remove the key but turns off as soon as I switch off engine..
the power was taken from fusebox for the system. What should be done to bring back the normal behaviour like stock rcd320 system.
Please note that I had also ordered a CANBUS adapter for pioneer F60BT, it should arrive in few days. will this solve the issue? Please help I'm totally confused
Here is the current wiring through which power is being taken.
https://dl.dropboxusercontent.com/u/35189045/IMG_20141223_204942279.jpg
As per the Fuse Box layout it is 5A used for Climate Control unit.
https://dl.dropboxusercontent.com/u/35189045/Polo-6R-Fuses.pdf
