Some of the new generation scooters have the 12V charging port as a standard feature. Is it possible to add the same in a 2010 Hero Pleasure?. I am not very familiar with the fuse box and the wiring of the scooters. Adding this will put and extra load on the old battery?.
Other than the regular 12V socket is there a unit with inbuilt mobile charger adapter or USB ports? (Refer the above pic). The reason for asking is if forgot to remove the adapter while parking no one should be able to remove it, so I am looking for a single unit with no separate socket and adapter. Not yet decided to do it as a DIY or from accessory shops, but I asked in 2 shops they said it can't be done!. Where in Pune I can get this done?. Please give your valuable suggestions.
