when my Swift was new 4 months back, I had replaced the stock head light bulbs with a 90/100w bulb with relay. It produced sufficient illumination and I never used high beams. But in the last few days, the illumination level and throw at higher speeds has reduces. Even with the car in bumper to bumper traffic, the illumination is lower. I knew about the issue of blackening of the reflectors with higher wattages and also knew that the housings were getting quite warm, so I used to switch off and go to fog lights in traffic jams. But still the illumination is nor less. The bulbs are Phillips and the relay etc is a no name brand. Thing is, high beam illumination is just fine. Should I try replacing the bulbs to see if that helps? Or should I look for alternative low wattage bulbs, such as LEDs which don't heat up as much? Please suggest
Ameyam
Ameyam
