Hai i just want clarifications on central locking devices
I have Ritz LXI trim with Auto-cop central locking kit but nowadays the central locking is malfunctioning as when i press Lock it does not response instantly take time after 30 sec i press lock it respond.
Also i have notice if lock instantly after i get down of car it unlock automatically due to this i have to double confirm every time the doors locked properly.So i have decided to go for OEM MGP central locking kit
Finally i have sucessfully updated my car from Lxi to Vxi i have noticed that wiring kit has in-bulit OEM central locking kit option to add device to activate the same.
I have enquired about OEM MGP central locking kit come with two models
I) Central locking with shock sensor - 4990
II) Central locking without shock sensor - 3990
I found another option that OEM central locking which comes with ZXI trim can be purchased separately with is locking module.
module cost is 4291
Alarm switch id 249
Siren assembly is 900
Hood and rear door switch is 229 set.
each transmitter 700
Also i i have doubt that OEM factory fitted key-less entry does ZXI variant comes with shock sensor inbuilt in the Key-less unit or its is normal one.
Doubt raised me because the Key-less transmitted has only two button (Lock,Unlock).
No silent lock or unlocking.
If any one has the ZXI variant can share their views
Can any one explain me the difference between ZXI locking module Vs Additional kit sold by maruti is worth
module cost is 4291
Alarm switch id 249
