For the most part, motoring law in most countries determines that your tires need a minimum tread depth to be legal. This varies from country to country but is normally around 1.6mm. To assist you in figuring out when you're getting close to that value, most tires have tread wear indicators built into them. If you look around the tread carefully, at some point you'll see a bar of rubber which goes across the tread and isn't part of the regular pattern (see the picture here for an example). This is the wear indicator. It's really basic, but it's also pretty foolproof. The tread wear indicator is moulded into the rubber at a depth of about 2mm normally. As the rubber in your tires wears away due to everyday use, the tread wears down. At some point, the tire tread will become flush with the wear indicator (which is normally recessed into the tread). At this point you have about 2mm of tread left - in other words it is time to change tires.
